It is currently Tue Aug 12, 2025 1:49 am
 Post subject: Bridge slots
PostPosted: Tue Mar 15, 2016 5:00 pm
This has been probably been covered before but what's the thoughts on slotting the bridge and using unslotted pegs
Just read it improves sound and response as more contact ?
Here's pic I just seen
 Post subject: Re: Bridge slots
PostPosted: Tue Mar 15, 2016 5:07 pm
Not so sure about the sound and response, but certainly a big improvement in longevity of the bridge plate and pins.
Lottsa posts on this.
These users thanked the author Colin North for the post: cablepuller1 (Wed Mar 16, 2016 1:30 am)
PostPosted: Tue Mar 15, 2016 5:28 pm
More posts on this than you can shake 100 sticks at.... most are in full agreement, unslotted pins good, slotting bridge/plate good.
These users thanked the author Rod True for the post: cablepuller1 (Wed Mar 16, 2016 1:30 am)
PostPosted: Tue Mar 15, 2016 6:09 pm
Agree with the "less damage to bridge plate". Disagree with the concept that more contact= more energy transmission. A common belief but unsubstantiated.
These users thanked the author Jeff Highland for the post (total 3): Bryan Bear (Wed Mar 16, 2016 9:06 am) • Hesh (Wed Mar 16, 2016 6:29 am) • cablepuller1 (Wed Mar 16, 2016 1:30 am)
PostPosted: Wed Mar 16, 2016 10:40 am
Slotting a bridge is good. I do it all the time. The photo also shows slots on the saddle which is a bad idea. At least I had bad results with that.
These users thanked the author Barry Daniels for the post: cablepuller1 (Wed Mar 16, 2016 12:25 pm)
PostPosted: Wed Mar 16, 2016 12:06 pm
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
I think a lot of people slot and ramp their bridges. Not sure how many slot their saddles for improved contact. Could certainly give you more of a break angle when you are using a wider saddle blank for intonation.
At least that's what I see in the picture in the OP.
Tim
These users thanked the author Tim L for the post: cablepuller1 (Wed Mar 16, 2016 12:26 pm)
PostPosted: Wed Mar 16, 2016 12:27 pm
What do you guys use to slot the bridge..my nut files are to big for this task
PostPosted: Wed Mar 16, 2016 1:04 pm
Dremel tool with dental bits.
You can make an efficient tool using a very fine tooth saber saw blade/s (at least 22 tpi) I found the saw sold specially for this purpose way too course and actually useless.
Ken Cierp
These users thanked the author kencierp for the post: cablepuller1 (Wed Mar 16, 2016 1:16 pm)
PostPosted: Wed Mar 16, 2016 1:13 pm
Last Name: Kincheloe
Zona saw keyhole blade, and knife style needle file.
Remember that if you want the guitar to support medium gauge strings, to make the slots big enough for them. Conversely, narrow slots are a nice way to hint to future owners if a guitar is meant for lights only :)
These users thanked the author DennisK for the post: cablepuller1 (Wed Mar 16, 2016 1:16 pm)
PostPosted: Wed Mar 16, 2016 2:07 pm
Along these lines if you like Tomastik strings slot bigger.... they have very wide windings..... gaah [headinwall] :D
PS: One more thing: With instruments with the bridge design being marginal for break-over angle slotting the bridge, top and plate can add break angle.
These users thanked the author Hesh for the post: cablepuller1 (Wed Mar 16, 2016 3:43 pm)
PostPosted: Sat Mar 19, 2016 6:49 pm
I reshaped some jigsaw blades on a grinder. They've worked well for me.
Brent
These users thanked the author bftobin for the post: cablepuller1 (Sun Mar 20, 2016 1:44 am)
PostPosted: Sun Mar 20, 2016 8:46 am
Ervin Somogyi has had pretty good results with it...
Mountain Song Guitars www.mountainsongguitars.com
PostPosted: Sun Mar 20, 2016 8:52 am
I don't think the slotted saddle is what makes his guitars sound good. More likely the super thin tops and bracing.
But I invite others to try this. Take one of your nice sounding guitars and make a slotted saddle for it and compare them. The one time I did this (on a Breedlove) the slotted saddle literally ruined not only the tone but also the volume. It was dramatic. I would be interested in hearing if other builders have the same results.
These users thanked the author Barry Daniels for the post: cablepuller1 (Mon Mar 21, 2016 1:34 am)
Users browsing this forum: No registered users and 52 guests
